Author Topic: HELP REQUIRED ALTERNATOR REMOVAL MK 3  (Read 1377 times)
Offline arwl1976
« on: 10 December 2010, 16:48 »
Hi guys im hoping you can help! Im trying to remove and replace the alternator on my mk3 2.0 GTi 8v. im hoping i can add some pictures here! i disconnected the battery and the electrical connector on the alternator
i have removed a bolt that was at the centre bottom of the alternator and im trying to remove this bolt at the top but it just seems to keep turning, am i doing anything wrong?
are there any other bolts i should be removing to get my alternator out?
many thanks in advance
http://i841.photobucket.com/albums/zz340/arwl1976/10122010140.jpg
http://i841.photobucket.com/albums/zz340/arwl1976/10122010139.jpg
Offline sharki786
  • GOT BOOST??
Re: HELP REQUIRED ALTERNATOR REMOVAL MK 3
« Reply #1 on: 10 December 2010, 17:23 »
you need to take the belt off 1st, slacken the alternator and the push it down as this will give enough space to get the belt of, disconnect the wires there might be another bolt same as the one your taking of. should pop out if it dont then gently hit it.  :tongue: but wait for another reply as i might be wrong.
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline arwl1976
« Reply #2 on: 10 December 2010, 17:42 »
im gonna seem stupid now, how do i slacken the alternator without getting that bolt off? the things not moving!
Offline sharki786
  • GOT BOOST??
« Reply #3 on: 10 December 2010, 17:43 »
push it down with the bolt loose. it has a spring to bounce it back up lol forgot the name
*****MK4 GTI T*****
Offline arwl1976
« Reply #4 on: 11 December 2010, 18:11 »
ok managed to get it out the spring underneath was a bit hesitant but just used some spray and got it out in the end
another question!!!
its a Valeo 70A 030 903 023E do i have to replace it with the same alternator or do i have a choice?
Offline sharki786
  • GOT BOOST??
« Reply #5 on: 11 December 2010, 23:35 »
best to replace with same or if you want more juice (subs & amps) see if there is an option to upgrade it. just pop over to gsf or eurocarfarts and see what they say
*****MK4 GTI T*****
