think at this point you will need to get your fuel pressures checked
quick thing to try, first disconnect plug to 5th injector and try, then if no help try disconnecting the plug to the wur. have you checked the 3 sensors on the side of the head? clean em up and try swapping the wires round. the red/yel wire is for the dash so can use this to check if the other 2 sensors are reading roughly the same. also make sure all 3 are black ones, if any are a different colour they're the wrong rating.
idle & co worth getting checked if everything else checks out
