Author Topic: MK3 AGG 20L GTI VERY BAD MPG + HOLDS BACK WHEN GUNNED !  (Read 1386 times)
Offline Monkeyboy1967
Hi i,am new here guy,s ,can anyone help ,my GTI is realy bad on fuel and hold,s back when you gun it ,its already had a new coil pack leads, dizy cap,rotor arm and plug,s ! It run,s alright if you drive it normaily /slow anyone got any advise what it could be !  My 1.8 SE mk3 golf was much better on fuel !
Offline sharki786
  • GOT BOOST??
Re: MK3 AGG 20L GTI VERY BAD MPG + HOLDS BACK WHEN GUNNED !
« Reply #1 on: 05 December 2010, 00:24 »
have you cleaned your throttle body out as its a very common prob also it would be good if you got it hooked up onto vag com and that will tell you all the faults aswel!
*****MK3 Anniversary*****
*****MK4 GTI T*****
« Reply #2 on: 05 December 2010, 17:23 »
Cheer,s m8 did,nt think about the throttle body ,will strip it down and clean it out,will have to get computer on it if it still plays up ,thank,s for advise .
Offline sharki786
  • GOT BOOST??
« Reply #3 on: 06 December 2010, 13:56 »
naa warries pal!  :wink:
*****MK4 GTI T*****
Offline rossbarry1
« Reply #4 on: 06 December 2010, 22:56 »
dunno if the mk3 is the same as mk2 but i have had the same problem with my airflow meter playing up! making my mk2 run really rich and pinking alot when pinning it! it was a dodgy connection with mine!
