Author Topic: Starting issue, advice/ideas please  (Read 2666 times)
Offline walchy01
« on: 15 November 2010, 14:22 »
Hi all
The problem is this, on turnover the car turns over really slowly as if battery is flat or has low charge,it has a brand new battery, then without notice turns quickly and starts, it has also  reset my clock to 86:00 ?????
Anyone got any ideas of where to start please??
Offline Steve_B
Re: Starting issue, advice/ideas please
« Reply #1 on: 15 November 2010, 14:49 »
Have you checked all the earth points?
Offline walchy01
« Reply #2 on: 15 November 2010, 14:54 »
Yeah mate, all cleaned and tightened up.... Thanks :grin:
Offline walchy01
« Reply #3 on: 15 November 2010, 18:38 »
Anyone please....
Offline clipperjay
« Reply #4 on: 15 November 2010, 18:51 »
Could be starter motor ?
Did the battery have full charge before attempt to start regardless if its a new battery?
Do you have a spark?
If you advance search and type starting issues or problem starting play with the words and see what comes up  :wink:
Offline DarnPB
  • Formerly Darnpistonbroke
« Reply #5 on: 15 November 2010, 19:44 »
It could be your starter. It is a case less one with the spigot bearing in the bellhousing. That bearing can wear out and give the false impression of a poor battery as the spigot end of the starter will not be captured.
Offline walchy01
« Reply #6 on: 15 November 2010, 19:51 »
Would you recon it or replace with a new one, how much for a new one,and where from and what make, Bosch???
Thanks
Offline DarnPB
« Reply #7 on: 15 November 2010, 20:08 »
Thanks
Replace the spigot bearing first that fits into the bellhousing. Its the cheapest thing to replace rather than the starter which can run into 10's. :wink:
