Author Topic: Oil in TIP/ on dv?  (Read 939 times)
Offline realrickman
Oil in TIP/ on dv?
« on: 22 September 2010, 15:05 »
Just replacing the old bosch valve with forge 007p  :grin:
But there seems to be quite a bit of oil residue where the pipes have come off on the bosch one. :huh:
Is this a problem? or just build up over the years?
Thanks!
Mk4 Anniversary 1.8T
Offline vwprime
Re: Oil in TIP/ on dv?
« Reply #1 on: 22 September 2010, 22:49 »
If you have never had it off i would  expect there to be some sitting arround in the pipe. it eather oil vaper when it got hot or if the car has had a little over fill, it end up geting chucked around in places like this. If you where to take off you Intercooler pipes i would thing you would find a little in there also.
TRANSFORM, & ROLL OUT!
Offline realrickman
« Reply #2 on: 23 September 2010, 09:06 »
Cheers mate!
Forge is on now anyway!
