Author Topic: Water leak behind fuse box!  (Read 1444 times)
Offline jim182
« on: 04 August 2010, 15:05 »
Ok so i was driving in the rain earlier and felt my foot get very wet, turns out that there is a fair amount of water coming in from somewhere behind my fuse box!
Does anyone have any idea where its coming from and how to stop it??
Jim
www.myspace.com/deadcannons
Previouse Dubs - Mk2 1.3, Mk3 1.4 SE, Mk2 1.6 Gti Replica - Currant boring company Audi A3 & Type 19 1.6 Driver
Offline The Mighty Elvi
  • I'm better than you today.
Re: Water leak behind fuse box!
« Reply #1 on: 04 August 2010, 16:06 »
Blocked drain holes near at top of OS  wing.
Could be either following the bonnet release cable and/or throttle cable.
The rubber grommets shrink with age allowing the water in.  Either replace cables or go A-Team and cover rubber in grease.
Jonathan.
Offline mwep201081
« Reply #2 on: 04 August 2010, 16:19 »
check all the grommets are present for the speedo cable, throttle cable and bonnet catch cable, and all blanking grommets are in place.
Replace any that are not.
It's always worth pocketing various grommets from the scrappy on any visit
Unblock the drain holes in the scuttle panel, usually blocked with leaves and general krud
Offline Agreeable Slick
  • Unit
« Reply #3 on: 04 August 2010, 16:22 »
search function works well for this.  :smiley:
