Author Topic: help with canon 1000d  (Read 2457 times)
Offline gazpowells
« on: 07 June 2010, 20:02 »
was taking pictures with my camera and then it just went off and the WB button was flashing,  camera will not come back on  :sad:
anyone had any problems like this?
Offline kdiz
Re: help with canon 1000d
« Reply #1 on: 07 June 2010, 20:08 »
When you say camera wont come back on do you mean you can't take pictures or the screen isnt coming on.
WB button flashing? I have a 500d the wb button on mine and it's a static button...
Maybe try the usual:
make sure it's charged
check the selection dial is set properlycheck memory is inserted correctly
Personally I havent heard of this  :sad:
Offline gazpowells
« Reply #2 on: 07 June 2010, 20:15 »
the WB button has a blue light in the middle and it was flashing blue, every thing else went off  :sad:
took battery out and gave it a charge and  now the camera does not turn on
Offline kdiz
« Reply #3 on: 07 June 2010, 21:15 »
do you happen to have an external flash fitted to it, some people say that uncompatible external flashes can screw the camera up....
Else I have no idea, may need to contact canon  :sad:
Offline shepgti
« Reply #4 on: 08 June 2010, 09:47 »
do canons have the same sort of reset that nikons do by holding in a couple of buttons? :undecided:
Offline Ridg
  • TDI - Soot Happens!
« Reply #5 on: 08 June 2010, 10:42 »
I think you're looking at a warranty job, where did you buy it from, and how old is it?
Offline gazpowells
« Reply #6 on: 08 June 2010, 14:33 »
My flash is a canon so should not be the problem
It's only 6months old so took it for repair today
they said can take upto 21 days  :sad:
