Author Topic: Crank Pulley/Bottom Pulley AGU Removal  (Read 2164 times)
Offline Luke-P
« on: 04 June 2010, 23:38 »
Hi Guys,
How do you get the crankshaft pulley off a 1.8T? Is it just the four bolts or do I need to take the crank pulley bolt out too?
Cheers.
Luke.
Offline Purely VAG
Re: Crank Pulley/Bottom Pulley AGU Removal
« Reply #1 on: 05 June 2010, 01:11 »
DO NOT REMOVE crank pulley = Timing will then be out.
1. Remove 4 allen key head bolts
2. Pulley comes off - May require prying due to being stuck.
Crank pulley you will see is what the cambelt runs along, behind the pulley so dont touch that.
✉ Jrd@PurelyVAG.co.uk // www.PurelyVAG.co.uk
Offline Luke-P
« Reply #2 on: 05 June 2010, 01:17 »
Cheers Jord! Thanks for the help!
