Author Topic: 2l bottom end with mk2 power steering set up  (Read 1170 times)
Offline e11ie
« on: 01 May 2010, 16:08 »
Hey
Just getting to the end of putting a 2l bottom end in my mk2. The bottom end didnt come with power steering but my golf did so I took the pump and bracket off the original engine and fitted it to the new engine.
However.......Im guessing I should also have swapped over some pulleys too because now I dont have enough room for all the belts I have! Am I correct in saying
I need the crankshaft pulley that has room for two pulleys like this.....http://cgi.ebay.co.uk/VOLKSWAGON-GOLF-MK3-GTI-LIGHTWEIGHT-ALLOY-CRANK-PULLEY-/130334065686?cmd=ViewItem&pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item1e58840416
And do I need a different water pump pulley too?
Cheers, Ellie
Offline e11ie
Re: 2l bottom end with mk2 power steering set up
« Reply #1 on: 02 May 2010, 10:20 »
ok so in answer to my own question  :rolleyes: after some research am I right in thinking I need.....
mk3 Alternator, mk3 power steering pump, mk3 belts, a different pulley for the water pump, (the one that sits the other way round) and the additional pulley for the crankcase sprocket.
But.........if I use a  mk3 power steering pump, can I use my original reservoir and lines that attach to the pump?
 :smiley:
Offline mattneck(Beavis)
  • Bristol's Own (DJ) Beavis ;-)
« Reply #2 on: 02 May 2010, 11:14 »
Mk3 alternator bracket that bolts to front of water pump, mk3 alternator and spring, mk3 pas pump and brackets, mk3 ribbed belt/pas  crank pulley, mk3 water pump pulley..
lines etc all fit no probs.. take the mk3 banjo bolt out and screw in the mk2 line  :cool:
Sig Removed. No Longer Applicable. New Sig? Nah. Not Yet..
Quote
Sharpo says: (16:57:39)
to be honest i dont doubt that half ggti users have a shortcut on their desktop for sharpie's last posts
Offline richard s
« Reply #3 on: 03 May 2010, 22:16 »
or just put all the mk 2 stuff back on and use that instead
