Author Topic: Insects welded to my bonnet  (Read 5409 times)
Offline VWKev
  • Please Support Non-Human Rights
Re: Insects welded to my bonnet
« Reply #20 on: 13 August 2010, 12:53 »
Kev I take it you wax the car every time you use the Tardis?
Tardis doesn't touch my dead insects on the bonnet. In fact I tried all sorts the last time to remove them and nothing shifted them.
Tardis, G101, Citric cleaner, WD40.
I've never had this problem before. In fact I thought Tardis would have done the trick as between it and G101 it has removed everything I have flung at it.
No, I hardly have to use Tardis now. I have Aquartz/Aquartz+ on the car at the moment (for a wee while now) and its very good at keeping most sh!t off the car, or if it is on the car its very easy to remove with no chemicals. If I have to use Tardis, I'll strip the car and run through my detailing routine again from scratch.
GTI mk6, 3dr Manual (Yes Manual! If I wanted a Taxi I'd hail one, not spend £1500 on one), Candy White, Full Leather, Xenons, ACC, 18", RCD510 + Dynaudio, DAB Radio, Winter Pack, Luxury Pack, Fiscon Bluetooth Plus, Golf R LED's.
"Some say he drives a Shopping car, and that his car dent was actually a beauty spot....all we know is he's called Captain Failboat"
Offline VWKev
« Reply #21 on: 13 August 2010, 12:54 »
Do you think the Autoglym removes my wax as well as the insects?
Probably will; best thing to do with dried-on insects is to soak them with water as soon as you can, this will re-hydrate them and they will soften up and wipe off easily. No need to use bug removers.
I can't see Auto Glym bringing out a product that will stip the wax or mark your paint work. it works great, soak the car, spray it on, leave it a few mins and wash! Job Done! I wouldnt be claying my car all the time eithers, swirl marks galore!  :rolleyes:
You shouldnt be getting swirl marks when claying, swirl marks are generally introduced at the washing stage.
Offline JonnyG
« Reply #22 on: 13 August 2010, 13:16 »
I've found that soaking the front end using warm soapy/waxy water followed by a blast from a jet washer works very well.
If you keep the car well waxed / sealed they will wash off much more easily.
Same with the windscreen .... Rain X (or similar) makes them glide off the glass with a normal wash/wax
Insect removers are quite harsh and many will strip your wax as well   :sad:
Current : Seat Cupra Lux, DSG, Magnetic Grey, Sept 2019
Gone :    Golf Mk 7 R, 5dr DSG, Pure White, March 2017
Gone :    Golf Mk 7 R, 5dr DSG, Tornado Red, March 2015
Gone :    Audi RS3, Daytona Grey, 7sp S-Tronic, Sept 2012
Gone :    Golf R, Rising Blue, 5dr DSG Mar 2010
Gone :    Golf R32, DBP, 5dr, DSG, Nov 2008
Gone :    Golf GTi ED30, Mar 2007
Offline VWKev
« Reply #23 on: 13 August 2010, 13:21 »
Personally I actually dont mind that. After all, isnt that what the wax layer is there for ? It's an unsung hero, its like the top digestive biscuit in a pack, that one is the hero as that takes the hit to keep the rest of the pack fresh  :grin: The wax being stripped is the sacrificial layer and first line of defence, so if it has to go, it has to go.
Offline SilverChariot
« Reply #24 on: 13 August 2010, 15:19 »
You're right - nicely put. :) So, simply re-apply wax after.
GONE BUT NOT FORGOTTEN!
Golf R - 5 door - DSG - Rising Blue Metallic paint - 19" Gloss Black Talladegas - Leather - RNS 510 - Parking sensors - Cruise control
R Forum - The place to talk Rs: http://www.rforum.co.uk
