Author Topic: golf 2.0 gti acceleration problem  (Read 1477 times)
Offline nlee268
« on: 15 March 2010, 09:00 »
hi,
i hope some one can point me in the right direction have a mk 3 2.0 gti and having problems in second gear around 2000rpm i sometimes get a kangeroo holding back for few seconds have changed normal stuff ie rotor arm dizzy cap leads plugs cleaned the injectors am now lost has any one got any ideas  its driving me crazy lol cheers
« Last Edit: 15 March 2010, 09:09 by nlee268 »
Offline tonysmallwood
Re: golf 2.0 gti acceleration problem
« Reply #1 on: 15 March 2010, 11:20 »
i have this same prob mate so will be good to see what it is
Suspected scammer - account locked please do not buy from this user.
Offline javalin
« Reply #2 on: 15 March 2010, 12:18 »
air filter? :wink:
J
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
Offline VR6_Wherry
« Reply #3 on: 15 March 2010, 12:45 »
I used to get this in my Gti, give the Throttle Body a good clean if you haven't already.
Offline nlee268
« Reply #4 on: 15 March 2010, 12:47 »
done air filter and throttle body it only happens at low revs around 2000rpm been told it may be the fuel pump that sits in the tank but thats not cheap lol rather try all other avenues 1st
Offline WillGTTDi150
« Reply #5 on: 15 March 2010, 12:51 »
My 150 diesel did this until I had it serviced a few weeks ago. The fuel filter was changed as well as the air filter and problem solved!
Hope this helps  :wink:
Offline javalin
« Reply #6 on: 15 March 2010, 12:57 »
+1 do fuel filter first.  £11 from VW and an easy change - just don't smoke whilst you do it!
Could also be ignition timing - is yours set correctly - mechanical (cam/crank) and ignition (dizzy pos).  Worth checking that the crank sensor wiring is OK - just fixed this problem with mine - similar problem.  Look under the oil filter with a torch. Check cam sensor wiring too (on dizzy).
Mine looked like : http://javalins.wordpress.com/2010/03/13/dodgy-sensor-wiring/
Failing that relays (ecu no30 and fuel pump no167)
J
« Last Edit: 15 March 2010, 13:00 by javalin »
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #7 on: 15 March 2010, 13:55 »
As Javelin mentions above, id opt for checking these parts, especially the crank speed sensor which is an uber common fault due to the cable breaking down due to heat generated from the engine and oil filter located above it. They normally just crumble in your hands as he's pictured. Mine caused running issues for months and ive heat wrapped the the replacement one.
