Golf mk3
hardmonkeys
stiff gearbox
Topic: stiff gearbox (Read 901 times)
valintino46
stiff gearbox
08 March 2010, 06:38 »
my 96 golf gti 8v has a gearbox that is stiff to change in all gears and is at its worse when cold, all gears select fine and there is no noise when changing or in drive, i suspect it could be oil related but just wondered if this is common place with this model.
valintino46
Re: stiff gearbox
08 March 2010, 13:06 »
Cable
Re: stiff gearbox
08 March 2010, 15:59 »
sounds like oil if you said every gear, and when you change it make sure you get the right viscosity.
boneybradley
Forum Supporter
Serious forum addict
Back in a Mk3...
Re: stiff gearbox
08 March 2010, 17:48 »
swap the gearbox oil for 75/90 synthetic...but also check the bushes/linkages as any of these being stiff could give issues (although i would expect bad selection issues too)
Golf mk3
hardmonkeys
stiff gearbox
