Great thanks man, did it and it runs much better now but smells very rich when cold and also a bit at idle, also it's really heavy on fuel 7KM/L!!Where should the ignition timing be set on this car?There is a hand made notch mark on the flywheel and I've lined up the cam and ignition timing with that mark.there are also two other notches cast on the flywheel either side of the punch mark?Does the ECU advance and retard the timing itself?
