Author Topic: loop on keyfob...  (Read 1034 times)
Offline ade_aidy_ady
loop on keyfob...
« on: 11 December 2009, 21:41 »
guy hope someone can help.......ive read a few topics on replacing the keyfob due to the loop part breaking off..........
ive order and got in my hands a replacement rear end of fob (the bit without the actual key)...............
what i need to know is ,,,,,,,,,,,,,, is it a simple change of bits out of my current rear bit ...i.e. battery and wee circuit board and putting it into new section and then just clipping in the bit that has the key and immobiliser .............?
or is there anything else u have to do ......................???
Thaks in advance !
Aidy
Offline andybod
Re: loop on keyfob...
« Reply #1 on: 11 December 2009, 22:16 »
hi mate yes simple job just swop the bit's necessary over and clip back together think  i just used the half with the loop and battery just be carefull fitting the battery back in the correct way atb andy
« Reply #2 on: 11 December 2009, 22:27 »
cheers ! thanks....
from looking at some pics online........is the small pcb board easy from current key easy to take out and stick in the replacement key..........??
aidy
Offline tonyg
« Reply #3 on: 12 December 2009, 00:18 »
cheers ! thanks....
aidy
Yeah it all comes out easily enough i had to use some soap on the little transponder capsule thingy in mine just take your time with it, well worth doing as my key was awfull and now it looks like i own a brand new dub  :cool:
« Reply #4 on: 12 December 2009, 13:19 »
all working .....!
wokrs a treat....replaced battery while changing over to new key............remote distance has increased greatly !
