Author Topic: Head Unit upgrade. Major improvement and Bluetooth  (Read 4138 times)
Offline Emeye
Re: Head Unit upgrade. Major improvement and Bluetooth
« Reply #10 on: 20 October 2009, 22:05 »
The tweeters may seem harsh due to two reasons. The rear tweeters are located directly behind you and are the nearest speakers to your ears (bad location anyway, but not a lot you can do except delete them and just use the fronts) and secondly that they are now overpowered and are usually the first speakers to distort at higher volumes. :smiley:
Well I had a bit of a play and realised that Loudness was turned on! No wonder things were harsh!
The new HU also really emphasises the problem with the rear tweeters being so close - in my previous cars when I have added a sub-woofer I've completely faded out the rears unless I had passengers in the back.  For the time being I've faded things forward a touch so I don't lose too much bass.
Not sure when I will get a chance to get the sub installed, but when I do I will decide if the sound is reasonable with the existing front speakers - if not they will be getting an upgrade, possibly to some 3 way Infinity speakers I've had my eye on for a while.
Thing is I don't want to spend a fortune and previously I've had some success with upgrading the HU and adding a sub but keeping the std speakers. My 2 BMWs were ok, but the best result was in my Seat Leon Cupra Mk1. :) You just need a decent HU with reasonable power and sub control.
Offline Alexander
« Reply #11 on: 21 October 2009, 10:43 »
just a word of warning about the infinitys. they are quite a deep speaker and to fit them you have to cut the metal door skin inside the door which can cause pressure problems for te alarm im told. I gave up and sold mine on, going to get some thinner speakers eventually.
