Golf mk2
same parts from a kr and a 1.8 carbed
Topic: same parts from a kr and a 1.8 carbed (Read 1126 times)
vwjack
30 September 2009, 22:21 »
wondering if things like my sump, oil pick up, exhaust manifold which is a 4 branch 2.5 bore thing, fly wheel and clutch are the same as a kr engine. ( i have a 1.8 8v carbed thing).
thanks
jack
Chris-White
Manufactured in Germany. Ruined in Britain.
Re: same parts from a kr and a 1.8 carbed
30 September 2009, 22:24 »
sump yes.
not sure on oil pickup.
no to everything else.
vwjack
30 September 2009, 22:32 »
thats sucks balls!
rubjonny
10k hero
Hello, my name is John and I'm a dub addict.
01 October 2009, 10:42 »
sump yes
flywheel yes, but BTDC mark in wrong spot, use haynes to remark it
oil pickup maybe
manifold no
clutch it depends on the gearbox you want to use, not engine
vwjack
01 October 2009, 12:57 »
wicked that sounds abit better.
ill get a kr clutch as mines going, im gona use the 020 gear box thats the same as the kr's aint it?
rubjonny
10k hero
01 October 2009, 13:13 »
you need to check the box code, the 8v 020 box has a smaller input shaft than the mk2 16v and mk3 2.0 8v 020 boxes
vwjack
Reply #6 on:
01 October 2009, 13:23 »
ahhh gona need more parts then i thought.
rubjonny
10k hero
Reply #7 on:
01 October 2009, 14:34 »
well you need a new clutch either way, just need to check the box code so you know if you need an 8v or 16v one
Golf mk2
