Author Topic: Rear brakes.  (Read 3730 times)
Offline DAVEMARX
Re: Rear brakes.
« Reply #20 on: 07 August 2009, 20:31 »
ive still got some forum handbags going cheap if it all goes hair and nails again....... :laugh:
Offline AudiA8Quattro
Re: Rear brakes.
« Reply #21 on: 07 August 2009, 20:32 »
You got your own handbag Dave?  :laugh:
Offline DAVEMARX
Re: Rear brakes.
« Reply #22 on: 07 August 2009, 20:48 »
actually its called a manbag and i only use it to steel bits and peices from the scrappy....  :wink:
Re: Rear brakes.
« Reply #23 on: 07 August 2009, 20:50 »
To steal caliper slide pin bolts?  :sick:
Offline DAVEMARX
Re: Rear brakes.
« Reply #24 on: 07 August 2009, 21:01 »
na i got a secret sexual desire for honda parts..... get me all wet they do
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
Re: Rear brakes.
« Reply #25 on: 08 August 2009, 01:51 »
When removing the rear caliper hanger bolts be prepared to have issues with them rounding off, being super seized or the heads even shearing off. They're notorious for this but this can be solved relatively easy by using Irwin bolt removers and the simply replacing the crappy ones with fresh OEM VW ones for a few quid.
Re: Rear brakes.
« Reply #26 on: 08 August 2009, 10:06 »
Correct.
Irwin extractors are an invaluable tool when comes to do this sort of job.
