Author Topic: JOM shocks/springs  (Read 2998 times)
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: JOM shocks/springs
« Reply #10 on: 22 July 2009, 14:49 »
yeah mine are the -40mm set, they look a little high at the mo but I haven't driven it since they were fitted so they will need a bit of time to settle
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #12 on: 22 July 2009, 14:57 »
so far only front mate, fitting the rears this afternoon
Offline warnesey333
« Reply #13 on: 22 July 2009, 15:02 »
Yeah my front didn't look TOO different, it does gradually start to bed in though and now I there is some difference.
The rears are easy enough to do, just make sure you do both wheels at once and drop each side down - I made this mistake and didn't do that :P
Had a right pain getting the springs clamped, I managed to do it but then dad came home and told me this way was much easier :P
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #14 on: 22 July 2009, 15:14 »
Yeah I know, did my coilovers myself last time, quite easy as it's the same principal as the old fords I used to own
Offline 6sr
« Reply #15 on: 22 July 2009, 15:18 »
A few people on ukmkIVs have been having problems with the rear shockers squeaking
http://uk-mkivs.net/forums/t/264617.aspx
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #16 on: 22 July 2009, 22:35 »
well rears are on and I'm off on a decent run 2moro so I'll let you know how I go
Offline warnesey333
« Reply #17 on: 22 July 2009, 22:37 »
good luck with it :)
I've been reading the comments on mkiv and am now slightly worried lol
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #18 on: 22 July 2009, 22:41 »
we shall see mate. If I have to keep replacing shocks I don't mind as long as they cover the cost of the new bolts/nuts you'll need every time  :tongue:
