Author Topic: Changing the Head Gasket  (Read 1192 times)
Offline th3_f15t
« on: 07 August 2009, 17:49 »
Quick question... When you change the head gasket, after doing all the skimming ect. do you need to run water and oil round for 1,000 miles then change it all or can you just leave it alone when finsihed?
Moving over to Flickr, sorry for the broken picture links!
gtigolfthree
Re: Changing the Head Gasket
« Reply #1 on: 07 August 2009, 18:12 »
Provided everything is ok I would just leave it although it never does anything harm to change the oil and filter.
Offline danny_p
« Reply #2 on: 07 August 2009, 18:13 »
if the oil in there isn't full of water i run it on that for 10 mins then change it.  if all the oil has turned to emuslion,  put some cheep oil in  run it on that for a day then do a oil change
if the coolant stays clean it's fine  if it keeps picking up oil you need to flush till it dosent
all the VW's have gone bar 1.
