Author Topic: Wheel bolts on 18s ?  (Read 1251 times)
Offline andytran
« on: 15 May 2009, 09:35 »
Morning all,
Im about to order some 18" replicas (genuines are too expensive and good secondhand are like hens teeth!!)
Im looking for a quick answer if possible before I order. The question is - will my existing wheel bolts (17" alloys) be OK to use, or will I need new ones? :undecided:
Andy - dont know if it matters, but the new alloys are ET45.
Re: Wheel bolts on 18s ?
« Reply #1 on: 15 May 2009, 11:49 »
If the wheels are reps / aftermarket then you will need new bolts as they will or should be a different taper to standard bolts.
Offline andytran
« Reply #2 on: 15 May 2009, 13:51 »
Cheers! Just got to figure out where to get the bolts from now!
andy
« Reply #3 on: 15 May 2009, 17:08 »
andy
Ebay is your best bet.
