Golf mk2
Mk 2 16v starting problem
Topic: Mk 2 16v starting problem (Read 2434 times)
rubjonny
10k hero
Hello, my name is John and I'm a dub addict.
Re: Mk 2 16v starting problem
Reply #10 on:
15 June 2009, 09:11 »
have you blocked off the 2 large holes in the inlet pipe/airbox where the over-run valve was? you'll have a massive airleak otherwise
Procomp
Reply #11 on:
15 June 2009, 12:55 »
Yeah....if there is any air leaking into the induction system, you'll not be able to start the car. Make sure it's all as it should be and sealed up tight or any holes are blocked.
Golf mk2
