Author Topic: abs fault on mk 4 golf  (Read 2028 times)
Offline kb_moto
« on: 18 April 2009, 18:48 »
the abs light is on and the fault reading is saying "01276 hydraulic pump-v64 signal outside tolerances intermittent" i've changed the abs pump thinking it was that but had no luck, the computer is showin the sensors are working fine. any ideas will be much appericated. thanks
Offline dai-cymru
  • 1989 MK2 16V
Re: abs fault on mk 4 golf
« Reply #1 on: 18 April 2009, 18:50 »
Did you clear the codes after changing it and did you change the pump and control unit as an assy??
Offline richw911
« Reply #2 on: 18 April 2009, 18:51 »
99% it will be the abs control module  :smiley:
Offline richw911
« Reply #3 on: 18 April 2009, 18:55 »
Offline kb_moto
« Reply #4 on: 18 April 2009, 19:30 »
thanks for your help the fuses was a bit corroded ive changed them and the lights gone off i will keep an eye on it thanks for your advice  :smiley:
Offline northeast_gti-t
  • "1.8T AGU"
« Reply #5 on: 18 April 2009, 20:16 »
nice one pleased your sorted then  :wink:
2000 Mkiv GTi 1.8T AGU
