Hey hey,im new to this so bear wi me please
i have had a mk3 gti 8v(k93) for a year now and i have just had it tested and it failed. rear disc pads and bearings which shouldnt be 2 difficult if i can get bolts out that holds the cradle to the hub managed to get 1 out but the other 3 have rounded and rusted so any ideas wud be sweet, but the other thing it failed on was the top bearing on the steering column and mount? i have spent all day taking the steering wheel off, all the trim off and column off but i cant see anything wrong with the bearing??? the only play i cud find was the ignition cowling moved when i moved the steering wheel, to me it looked like the sheer bolt that holds the cowling to the column wasnt tight enuf. i have been to euro car parts for bearing and sheer bolts but i was told dealer parts only?? is this true?? when i told the dude at Euro he laughed and said i must have swinging on the column for the bearing to go!! wen i picked the discs n pads n stuff up from a garage i took the cowling wi the bearing in and the mechanic said the bearings looked fine. cud it be that the bolts needed replacing??
i dont want to go to the trouble of changing the bearing if its only the sheer bolts needed replacing.
any info wud be great.
