Author Topic: 1.8t diagrams, info, etc  (Read 1135 times)
Offline LazyLunatic
  • MK3 20VT Project
« on: 01 March 2009, 15:36 »
hi all, got a mk3 but 1.8t going, so will be sort of mk4   :tongue:
just looking for some advice, etc. not familiar with the 1.8t engine as such, i got the wiring harness off ready to be sent off to qpeng. got the secondary air pump off as i dont need it and i also need to get the fuel evap system off, but not what it looks and which parts need to be removed?
i got the AUM, any parts that are worth replacing due to common faults? i found the y shaped pipe from the pcv was corroded and needs replacing. part no 06a 103 221? vw dealer for it?
also as for fueling, can a mk3 gti 16v pump be used? or is the 1.8t pump best?
been on the net searching for info, found a couple diagrams, but could use some help ;)
thanks peeps  :smiley:
« Last Edit: 01 March 2009, 18:04 by LazyLunatic »
