Author Topic: Rear heated screen  (Read 963 times)
Offline Bcarm
Rear heated screen
« on: 16 February 2009, 22:17 »
Does anyone have any idea why my rear heated screen dunt work.  I have a 91 8v.
I have checked the connections and have about 12v to the left hand connector and nothing at the other (i asume this is to ground) but it dosn't de-mist at all.  Any help would be apprieciated :smiley:
Offline DarnPB
  • Formerly Darnpistonbroke
Re: Rear heated screen
« Reply #1 on: 16 February 2009, 22:33 »
Look near the top right hand tailgate hinge and you will find some sheathing containing the tailgate electrics. Expose the wires and repair the damaged ones that you find. It may probably be the earth one that is broken.
Offline Bcarm
« Reply #2 on: 16 February 2009, 23:08 »
Thanks but i have checked that no broken wires.  Where would the earth run to because they run into the body from the tail gate and dissappear :embarassed:
Offline DarnPB
« Reply #3 on: 17 February 2009, 05:19 »
They may not be damaged where you can see them. If you have 12v applied at the left hand side of the element, then either the ground is not connected, or there is a break in conductivity within the element at the connecting points. Disconnect the right hand side of the element and test for continuity to earth from the lead. If it is good, then go to the left hand side of the element and look at the connecting tab to element. You may have a dry joint there. Test for continuity accross the element via the connecting tabs. You could try reflowing solder back to make the connection good, otherwise, remove another rear window from a scrapped car and fit that one. :smiley:
Offline Bcarm
« Reply #4 on: 17 February 2009, 13:52 »
 :wink:Thanks I will try that tonight.
