Author Topic: noise from clutch  (Read 1010 times)
Offline shadymofo
noise from clutch
« on: 04 March 2009, 18:18 »
I've recenty had the clutch replaced on my 89 8v pb digi,i took it for a short run and from stoppin at the roundabout,it stalled think i missed 1st not sure but it stalled then it started then i heard a clunk then a bang and the metal against metal noise...i can get it into gear but i get the noise still..if i start the car with the clutch pedal down i dont get the noise till i start to let the pedal out slowly the noise returns...sounds like i.ve done something to the clutch cos there is no noise when the pedal is down..any ideas
thanks
Re: noise from clutch
« Reply #1 on: 05 March 2009, 13:55 »
that doesnt sound healthy at all, miught be you have lost some flywheel bolts!  You want to get that box off again asap, loose bolt + flywheel + aluminium gearbox casing = casing looses!
