hi all, just getting my self some bbs ch reps in 18x9j all round, yes i know you can get fronts on 8j and rear in 9j but i like the deep bowl on the 9j for a more aggressive stance
i have been doing alot of research on this and cant really find the info im looking for i know some one on mkiv was running the same but with 35 profile tyre
http://uk-mkivs.net/forums/t/334094.aspx?PageIndex=1problem is i switched to 35 profile tyre on my 8j and within a week took the sump out so i rasied the front a little and 60 miles later took the sump out again (big thumbs up to topher and dub unit crew for plugging sump up enough for me to get home)
i have just ordered a shallow sump and dont want it to happen again so wanna go back up to 40 profile i cant understand it as im not that low unlucky i guess!!
so a few questions i know a 215/40/18 can but put on a 9j was gonna space rears out by 20mm but not sure how to set up the front
wheel spec wil be
18x9j et35 215/40/18
what spacer can i run on front to clear the coilover (5mm??) as want a little poke but not to much
and do i need to remove the helper spring on the coilover so that the wheel/tyre does not scrub on the adjuster ring
any help guys as im new to this stretching thing i got it wrong once and took out 2 sumps :-(
