Golf mk2
mk2 brake upgrade advice please 288mm 4 stud discs?
Topic: mk2 brake upgrade advice please 288mm 4 stud discs? (Read 3186 times)
luesautos
Here all the time
5doorwhore
30 August 2009, 23:45 »
i have got mk2 16v hubs running girling 54 calipers and would like to know what i need to do to get them to run 288mm discs and what 288mm discs are 4 stud thanks.
Last Edit: 04 September 2009, 00:03 by luesautos
Diamond Hell
Serious forum addict
Opinions я Us
Re: mk2 brake upgrade advice please
31 August 2009, 22:14 »
I think you're thinking of the 280mm brakes. As far as I'm aware the 5-stud 288 brakes are only available in 5-stud flavour.
To go to 280mm you just need the caliper carriers, rotors and pads, bish bosh, off you go.
luesautos
Here all the time
5doorwhore
04 September 2009, 00:03 »
so there are no 4 stud 288mm discs avalible as i do not want to lose my wheels as they are 4 stud?
Diamond Hell
Opinions я Us
Re: mk2 brake upgrade advice please 288mm 4 stud discs?
04 September 2009, 00:16 »
Isn't 280mm enough for you?
danny_p
Forum addict
04 September 2009, 01:06 »
you chould get 4 stud 288's but it would cost as there not an off the shelf part in the correct bell for anything. so unless you want to get involved with the horrible game of buying blank disks, haveing them drilled then sticking spacers behind them your choices are 280mm or 305mm
all the VW's have gone bar 1.
luesautos
Here all the time
5doorwhore
11 September 2009, 11:19 »
looks like its the 280mm then what calipers would be best to run i have some girling 54s but have seen some twin pots on e bay?
danny_p
Forum addict
Reply #6 on:
11 September 2009, 11:36 »
std callipers fine. if there not enugh sod the slideing twin pots and get ali 4 pots
luesautos
Here all the time
5doorwhore
Reply #7 on:
17 September 2009, 23:32 »
lol trying to keep it all vw related
danny_p
Forum addict
Reply #8 on:
17 September 2009, 23:36 »
slideing twin pots are heavy and don't have a bigger pad singel pots can lock most most tyers up quite easaly unless the there serious tyers or the pads are made of cheese.
the ali 4 pots can be vag.... ish porsche or seat brembos
Golf mk2
