Author Topic: Where else to look for a GTI?  (Read 11107 times)
Offline Ridg
  • TDI - Soot Happens!
Re: Where else to look for a GTI?
« Reply #110 on: 04 October 2007, 15:57 »
What adapter's that??
the "brackets" you've bought
http://www.caraudiodirect.co.uk/vwse...ors-p-517.html
did they not come with screws?
« Last Edit: 04 October 2007, 16:05 by The_Ridge »
Offline Madmax
« Reply #111 on: 04 October 2007, 16:03 »
Oh :) I havn't received them yet. I've got some screws incase.
« Last Edit: 05 October 2007, 00:18 by Madmax »
Offline Madmax
« Reply #112 on: 05 October 2007, 10:27 »
Another situation. :undecided:
When you replace the front stock speakers with components & power them via an amp,
what happens exactly with the rear speakers? Will the 'stock' sound still be coming through,
is it just a case of adjusting the fader more to the front so they don't blow?
Thanks.
Offline Ridg
« Reply #113 on: 05 October 2007, 10:31 »
simple solution is to only run the fronts of the amp, and leave the rears running off the head unit.
basically only run the RCA cable to the amp for the fronts and then back from the amp to the speakers.
Offline Madmax
« Reply #114 on: 05 October 2007, 10:34 »
Thanks alot mate,
So basically, i don't touch the rear speakers or the wires from the head unit, just replace the adapter to connect
the RCA cable, run it to the amp & run the front comps from the amp.
I was worried that the amp would interfere with the rear speakers & i'd have to run the speakers from the amp.
But i'm guessing they'll blow if i don't fade more to the front?
 :smiley:
Offline Ridg
« Reply #115 on: 05 October 2007, 11:03 »
almost.
if you're planning on using the existing wiring eg the loom that runs from the head unit to the speakers, then you're going to have to cut and crimp the loom.
there will be 2 wires (don't ask me which) that currently run from the head unit to the front speakers, you'll need to cut these and then crimp the return wires from the amp to these, when you cut the wires leave enough so that you can crimp them back if you remove the amp.
Offline Madmax
« Reply #116 on: 05 October 2007, 11:06 »
But i don't have to, right? Would it be easier to do the wiring straight from the amp & leave the existing
wiring where it is, but removing it from the HU if that makes a difference?
How are the stock rear/fronts connected to the hu btw? I've been trying to find some piccies, but no luck.
Chris,
Offline Ridg
« Reply #117 on: 05 October 2007, 11:53 »
Chris,
yeah you can go straight from the amp to the speaker, just you'll have to route the wire all the way from the amp location (normally the boot) to the speakers and it can be a squeeze.
Offline Madmax
« Reply #118 on: 05 October 2007, 11:59 »
Thanks for that. :wink:
Bit o/t but has anyone used one of those £20 Aux-In Adaptors/Cables to connect an ipod? What makes fits the VW/Gamma unit (JVC/Alpine/Pioneer etc as i'm thinking of buying one as my CDs keep ejecting..
http://www.caraudiodirect.co.uk/ipod-friendly-auxin-adaptorscables-c-2121_697.html
« Last Edit: 05 October 2007, 22:42 by Madmax »
