Have you removed the belt yet?
If not, don't bother with TDC, just mark it all up with tip-ex and refit the new belt.
If you have, then you should have marked up before hand
Why not just use the factory timing marks?
cos as its been said over the whole thread, pulleys and flywheel may have been put on wrong throughout the cars life.
If that was the case the car would not be running properly, if at all.
Its actually very hard to fit the pulleys on wrong.
The cam sprocket has a timing mark, you cannot fit this sprocket incorrectly.
I think there is also a flat tooth on the crank sprocket, but i can't remember exactly as i haven't worked on one of these for years.
Do the job properly, by the book.
