Author Topic: yearly inspection ,small fail  (Read 531 times)
Offline forsh
« on: 04 March 2012, 06:57 »
went for my yearly inspection last week
failed on 1 rear disc brake
getting a pair of new ones next week
also didnt fail on this but could be fixed ,hieght adjusters for lights
ive got motors there,but he said they didnt work
what could it be
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
Re: yearly inspection ,small fail
« Reply #1 on: 04 March 2012, 12:15 »
I would say either the motors them self are shot or the inner lenses of the headlight have popped out of the motor adjuster, i think its like a little ball joint or similar.
Try moving the switch and listen with the bonnet open, you will hear if they work.
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline forsh
« Reply #2 on: 04 March 2012, 15:34 »
changed my bumper today so while i was doing it,i checked the motors,one had a poop load of rust inside the motor,they come apart so easy,,1 motor was fine 1 was grim
unpluged the grim one and tryed the switch,nothing happened,
is there a fuse ,didnt have my meter to check the volts
