Maybe you'd like to explain how what I said is 'completley inacurate'?
Unless you're running some sort of noise-making system, rather than a dump valve, the valve definitely *should* (for performance purposes) be mounted after the turbo, in the pressurised section of the inlet.
The possible reason for your confusion is that on the G4 the valve is designed to recirculate into the inlet manifold, as standard. The air that is released is definitely coming from the pressurised side of the turbo.
Maybe if the initial poster read the instructions that came with his valve he might find (as a quick skim read of the Forge website told me) that:
As a bonus we also offer the ability to convert the valve to recirculation only mode for those times when stealth running is required.
Which means his valve is probably set to recirculate the air, not make the lorry/bus noise. I suspect a quick read of the instructions will yield the relevant screw to turn to set it to 'loud and pointless'.
