Golf mk4
Wazzzer
Slight vibration
Topic: Slight vibration (Read 613 times)
redevo1
Here all the time
golt gti 1.8t AGU
Slight vibration
05 October 2008, 17:36 »
Getting a vibarition from under the front off off the car but soon as I surpress the clutch it stops? Not the end off the world just wondering what it could be?
God I've got a golf I'm getting old!Full Recaro leather with arse waming seats, the reason for buying a Golf!Spec: R tech remap:Eibach Fr+Rr ARB:Powerflex ARB bushes:Forge BOF DV:Silicone TIP:Induction kit:Jamex suspension:312mm big brake setup: EBC pads F+R:Vr6/g60 clutch:5mm-fr+15mm-rr spacers: Anni front & rear Valances & Anni rear roof spoiler: Silicone hose boost/Breather kit.
golfgtidan
Re: Slight vibration
05 October 2008, 17:39 »
when you push the clutch it stops?! could this possibly be the release/thrust bearing inside the gearbox?!
box out jobby to fix!
1999 1.8t : Winter Pack : Kamei Mesh Grille : Forge 007p D/V : Carbonio Cold Air Intake : R-tech remap : 18" Toora Alloys : -30mm Eibach Springs : Smoked Side Repeaters : Hella Magic Colours Rear Lights : Hella Black Headlights : "hid" Headlight Conversion : Aero Blades Front & Rear: ECS KVW100 Window Control Module : Milltek resonated cat back
richw911
10k hero
The Linkmeister and an OEM Freak.
05 October 2008, 17:47 »
As said sounds like the thrust bearing.
redevo1
Here all the time
golt gti 1.8t AGU
05 October 2008, 17:53 »
Clutch is fine and clutch action, thought it might have been something rubbing ganist the exhaust?
richw911
10k hero
05 October 2008, 18:02 »
Quote from: redevo1 on 05 October 2008, 17:53
Yeah but the bearing can wear out before the clutch. Its not going to do any harm if you can put up with it.
Golf mk4
Wazzzer
Slight vibration
