Author Topic: *** KO3s fitting - Job done ***  (Read 11853 times)
Offline Devilz
  • Cruisin is not a crime
Re: Bought KO3s
« Reply #20 on: 12 January 2010, 17:30 »
rememer to get all the bits aswell for fitting, oil, oil filter, G12 coolant, nuts, bolts, gaskets etc.
i just changed oil and oil filter  :cry:
Hulmie, can you help with part numbers for nuts, bolts and gaskets etc plz??
Offline bobbarley
  • I'm kind of a big deal...
Re: Bought KO3s
« Reply #21 on: 12 January 2010, 17:31 »
:afro:
Offline Devilz
Re: Bought KO3s
« Reply #22 on: 12 January 2010, 17:35 »
found this under ko3/ko3s part numbers thread in maintaince section
Here they are and the quantity you will need.
1J0 253 115 A (turbo - downpipe gasket)
N 102 090 05 (nuts x 4)
056 103 377 (washers x 4)
N 013 851 4 (oil feed pipe washers x 2)
N 013 814 9 (water pipe washers x 4)
058 145 757 C (oil return gasket)
N 014 702 13 (oil return bolts x 2)
06A 253 039 E (turbo - manifold gasket)
b 058 145 540 (bolts x 3)
058 145 791 (washers x 3)
058 253 039 L (manifold - head gasket)
N 902 002 01 (nuts x 13)
N 903 572 01 (washers x 13)
anything else required?
Offline bobbarley
Re: Bought KO3s
« Reply #23 on: 12 January 2010, 17:38 »
I'd go with the parts from the picture above, as posted by a guy on the forum (Patch) that's done the upgrade  :sad:
Offline Devilz
Re: Bought KO3s
« Reply #24 on: 12 January 2010, 17:40 »
i just printed that image, i'll take it to stealers tomorrow and place the order  :smug:
but the invoice is from sept09, do you reckon part numbers will be still the same or should i tell them i need for ko3s turbo??
what about insurance, what should i tell them about it so premium doesn't go any higher  :lipsrsealed:
« Last Edit: 12 January 2010, 17:43 by devilz »
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: Bought KO3s
« Reply #25 on: 12 January 2010, 17:40 »
lol that typed list is mine  :grin:
Offline bobbarley
Re: Bought KO3s
« Reply #26 on: 12 January 2010, 17:40 »
And if anything goes wrong, blame Patch!  :grin:
Offline Devilz
Re: Bought KO3s
« Reply #27 on: 12 January 2010, 17:43 »
yes mate its yours!! used Ctrl + C and Ctrl +V  :rolleyes:
just to let you guys know, i got all screws with turbo as well but i reckon cause its from ibiza they won't fit on golf  :huh:
« Last Edit: 12 January 2010, 17:45 by devilz »
Offline Hulmie
  • White MK4 1.8T AGU K03s
Re: Bought KO3s
« Reply #28 on: 12 January 2010, 18:07 »
its best to get all the bits listed mate. I got all mine just before xmas. I personally i would change the oil & filter again as they have to drain this. Also make sure you get some G12 coolant as Nick normally washes himself in it whilst draining the car.
All in all i think the total came to roughly £100 inc oil, filter and 2 bottles of G12. I'll dig out my receipt later on as i know some of the part numbers i quoted had been superseeded.
Offline DarkGti
Re: Bought KO3s
« Reply #29 on: 12 January 2010, 18:30 »
leeroy has got most the parts for sale
http://www.golfgtiforum.co.uk/index.php?topic=139427.0
