One of the front oil seals has given up the ghost on my 1800 Mk1 GTi. I'm in the process of removing the belt covers etc. at the moment to find out which one has gone
Have decided to replace the crankshaft, intermediate shaft and camshaft seals all at the same time as I don't want to be doing this again in a hurry .
I don't have the option of removing the engine from the car, but need to remove BOTH the crankshaft timing belt sprocket AND the intermediate shaft sproket to access the oil seals. This is where my problem starts......
Everything I have read so far says that both of these sprockets are a real PITA to remove requiring the application of some heavy duty torque to get the nuts holding them off free. Main problem seems to be preventing the shafts from turning while trying to undo the nuts...
One suggestion I have seen is to get a trusty assistant to put the car in fifth and then stomp on the brakes while I go hell for leather with the breaker bar and socket on the crankshaft nut
. Will this work for the intermediate shaft too?
I've never tried this before so any tips or info would be REALLY welcome, especially from those that have "been there done that".
I'm still in shock after buying one of the oil seals from VW today - ?14 + VAT
. GSF do them for about 4 quid, but from what I have heard quality wise they are not up to snuff... I don't want to be doing this again in a few weeks time.
Cheers,
Chris
