Hi all,
Well its time for a little update on how my ABF conversion is going, having recently gotten back to working on the car since breaking my elbow back in April! i really miss driving this car now!
I now, pretty much, have finished both of my looms, the engine loom has been re-fitted to the car and the engine is now in place, temporarily for now as i just want to test my wiring skills!
As per Rubjonny and Danny_p's advice i have totally stripped both my engine looms and have made a custom Mk2 ABF loom, im just waiting for my VW loom tape to be delivered so i cam wrap it once it is removed after checking.
I have also rebuilt my Mk2 lighting loom, and using danny_p's website as a guide i have incorporated an upgraded headlight loom. Although i took my own approach on this and have re-rooted the entire lighting loom so it now all goes down the passenger side of the engine bay, and finishes by the battery where i have adapted a mk3 engine plug so i can remove the intire front lighting loom (including the resin block with my relays built in). i am really happy with how this looks as it has tidied up my engine bay no end!
With the engine in place i have attatched my old 8v exhaust system, so i now have a standard ABF manifold and 2 into 1 downpipe and this attatches to my custom 63mm centre section and onto my 2 standard VW rear boxes. i know this set up wont be ideal as it may be a little restrictive, but my only other alternatinve at the moment due to no funds is a powerflow exhaust i have from a vr6 i scrapped that has a 4 inch tailpipe!
so i think i'll stick the the OEM look
This morning i put my radiator in place to see how it looked, to my suprise it seems that my top hose will fit fine if i cut about 20mm off the end, and the bottom one will be fine once i swap the stat housing to an 8v one?!
My next step is to finish up the last few wiring jobs, i have a few loose wires and plugs im unsure of!
1) On the drivers side of the engine bay i now have 4 plugs, my lamda plug, outside temp sensor, and 2 black 2 pin sockest which i presume are for the airflow meter and carbon canister, but i dont know which is which?! one has Blk/Wht and Grn/Yel and the other is Wht/Yel and Brn/Blu?!
Is there any advantage to me fitting the carbon canister?
2) By the throttle body i have another black plug coming from the same part of the loom as the TPS it has Blk/Brn going to it?! I have found this pic on the net and it seems to show that plug connected to the pipe that comes from the block breather?!
I was hoping to be able to just block off the block breather (as i did with my 2ltr AGG conversion) will this cause any problems?!
2a) Is that a Seat Toledo airbox and inlet pipe that connects to the throttle body?! what year would that be 92>97?! Did all models have the same airbox? Does anyone know of one for sale as i love the standard look it give, i only have a very cheap and nast cone filter with alloy tube fitting kit
only other thing i can think to do is to fit the mk2 8v airbox i have and modify the AFM?! that is on top so it is open?! any thoughts, (sorry if that makes no sense!)
3) From my ECU i now have 3 wires left over Grn/Wht, Blu/Wht and Violet/Wht according the the fusebox FAQ these are for the instrument panel just want to double check before i cut for good!
4) On the round plug that connects to the engine i have a red wire that is loose, its coming from row 5 pin 17, The FAQ says it's Pin 87 K20/ (+v) to injectors. so i presume this goes to ignition live? what does the pin87 K20 mean?!
5) Coming from the engine side of the round plug i found 3 wires that seem to have had a plug cut off, they seem to head towards the gearbox?! not sure exactly on the colours but i can check them if needed.....
6) ontop of the throttlebody there is a small vac line that goes to the airbox, and a larger one that seems to go towards the carbon canister?!
also just to the right of the throttle body there is another vacline ontop of the manifold, where does this go?! to the ECU or does it join to the one that goes through the bulkhead?!
7) there is a fitting on the back left corner of the inlet manifold as u look at the engine, any ideas where this connects?!
i think that is pretty much it for now, although i know i have a couple of spurious wires behind the fusebox, i'll make a note of these later!
Many many thanks in advance for any help anyone is able to give!
