Golf mk4
Wazzzer
WHAT IS A FORGE 007P AND A FORGE TIP????
Topic: WHAT IS A FORGE 007P AND A FORGE TIP???? (Read 847 times)
jake
05 January 2009, 01:22 »
im confused i keep hearing on the forum about forge 007p and forge tip, can some1 please tell me what these are??
i have the forge 007 dv valve, or is it something completeley different
thanx
Immortal
Here all the time
1.8 Turbo GTI (AUM)
Re: WHAT IS A FORGE 007P AND A FORGE TIP????
05 January 2009, 02:01 »
the 007p is the dump valve. That's what you have fitted!
The Forge TIP is a Turbo Intake Pipe. Basically the forge version is stronger than the stock TIP which is prone to collapse under high boost.
Check Out My Mods
Ivor Mk4 Turbo
Forum addict
2014 PP GTi Manual
05 January 2009, 06:58 »
http://www.forgemotorsport.co.uk/
Current Car:- 2014 GTI PP manual, white.
Make way for..... 'The Silver Bullet'!
227
bhp, KO3-S'd AGU,
R-TECH Spec 2 map
, Forge 007P,
Blueflame Turbo-back
, Eibach -30mm's, YellowStuff front/RedStuff rear pads, Goodridge braided lines,
TT Short-shifter
, R32 Dogbone, TT W/B bushes, Forge TIP, G60 fly/VR6 clutch, 5.5 ltr washer bottle,
Car now for sale >>>
http://www.golfgtiforum.co.uk/index.php?topic=140614.0
jake
05 January 2009, 14:33 »
thanks for the reply matey!!
javascript:void(0);
Golf mk4
Wazzzer
