Well it seems I've found ANOTHER niggle with the car....noticed wet front/rear drivers side footwells this morning
I've just bled the front door nipples and pipe cleanered the front sunroof holes, this removed a load of gunk from them so they're now draining nicely but for some reason on the drivers side there is also a dripping leak coming from where the roof lining meets the A pillar, this dribbles down the A pillar, down the dash and onto the floor so is obviously the source of the soaked carpet problem.
I'm going to assume the pipe might have come loose from a connector up there. Can anyone tell me how to remove the A pillar trim please so I can investigate ? Is there a guide to drop the roof lining anywhere ?
Also where are the rear sunroof bleed nipples ? I cant get to the holes as they seem to be hidden behind the sunroof glass.
Sorry for all the Q's...I have searched !
