I have a '89 1.6 driver, 150k engine has seen much, much better days...It rattles like a bastard - spanners in a biscuit tin job. Now I'm new to Golfs & their engines, and I gather (from reading here) that the 1.6 8v is prone to a little bit of a tappet/head rattle, but this is bad.
So is the following the best way for a skint guy to keep it moving:
Try oil change first (filter, pull sump & check oil pump, pick up sieve etc and flush).
Failing that replace the head & oil pump with a (preferably low milage) complete head from a scrappy etc. On this note I am I right in thinking I can use the head off either a 1.6 or a 1.8 8v and use the original, if hideously complicated pierburg carb?
I am not trying to tune it at all (well not right now anyway), but for some reason there appear to be more 1.8's on ebay... ;o)
On that note, anyone in the SW got a spare good head & pump lying around for a few notes?
Also before I splash out £20 on a new clutch, I gather there are a couple of different Gearbox's I could have, like an 084, 085 or 020. How do i tell them apart & do they have a different clutch fitment or anything like that?
Sorry about the idiot questions but I am new to VW ;o)
DD
