The garage
truble starting
Topic: truble starting (Read 1366 times)
homer
GTI forum regular
truble starting
18 December 2005, 20:48 »
i have truble starting my car in the cold its a mk2 driver can any one help plz it runs ok when ive driven it .
and after leaving it for most of the day it starts fine .
thanx.
dubslug
Re: truble starting
19 December 2005, 14:27 »
this car has no return fuel line on it either if this helps anyone with the problem???
1992 pearl grey 8v
rubjonny
10k hero
Hello, my name is John and I'm a dub addict.
Re: truble starting
20 December 2005, 17:31 »
Have you read through my Pierburg 2e2 FAQ?
dubslug
Re: truble starting
21 December 2005, 06:37 »
rub its my old car, it has a webber carb on it, also a 1.8 head gti cam and exhaust system
it cranks over but its as if its not getting fuel or a spark then all of a sudden it fires and the revs rise real slow, oh its also got manual choke too
1992 pearl grey 8v
rubjonny
10k hero
Re: truble starting
21 December 2005, 08:06 »
does it have the fuel reservoir on the front of the engine? I'm guessing not as there is no fuel return?
dubslug
Re: truble starting
21 December 2005, 21:07 »
no rub, im thinkin maybe we should put on on it, am i right in thinking fuel reains in there when u switch the car off??
as it stands he has two in line fuel filters and thats it??
1992 pearl grey 8v
rubjonny
10k hero
Re: truble starting
Reply #6 on:
21 December 2005, 21:21 »
its there to seperate fuel vapor I think, so would prob run better with it on there
Sure it isn't safe without a return line as well!
dubslug
Re: truble starting
Reply #7 on:
21 December 2005, 21:38 »
mine was done by a mechanic who said he always did it on golfs??
its weird this car it turns over wont start then fires up out of the blue
1992 pearl grey 8v
rubjonny
10k hero
Re: truble starting
Reply #8 on:
21 December 2005, 21:48 »
Hmm I'm not sure why you would need to, except perhaps it might up the fuel pressure slightly. I guess it could 'cure' a worn fuel pump...
dubslug
Re: truble starting
Reply #9 on:
21 December 2005, 21:53 »
fue; pump is run off the crank?? plus ive replaced that one too
1992 pearl grey 8v
The garage
truble starting
