Here we go again!
I want to lower my Golf GT TDi - for two reasons:
1) Looks
2) Improve handling
I've looked at both spring and shocks as well as coilover suspension but I'm not sure which to opt for. My main concern is maintaining acceptable ride quality but achieving a pleasing stance.
Coilovers have the luxury of being fully adjustable, so the ride can be wound up or down to suit. I want a drop between -30/40mm, depending on practicality, ie, I don't want to worry about speed bumps or the front ARB rubbing the drive shaft. Having done my homework there doesn't appear to be any hard and fast rule regarding at what point the ARB will need replacing/upgrading to avoid problems. Some people have gone -50mm with no problems, but others have gone for less of a drop and needed to change ARB and drop links.
However, I have been warned off coilovers because they are said to be too harsh for everyday use and are geared more towards the hardcore enthusiasts.
Springs and shocks on the other hand don't offer any flexibility meaning you're stuck with the drop you've intially chosen. From what I've read, you sometimes don't even get that. -30mm springs might only drop by -20mm, which I think based purely on looks, would be a complete waste of money. However, from what I've read, they're meant to be more forgiving on a daily basis when compared to coilovers...?
So, first question is, will coilovers wound down -30/40mm provide an acceptable ride? Second question is will coilovers wound down to this degree be harder, softer, or pretty much the same as springs/shocks giving the same drop?
I'm putting a lot of thought into this because I think choice of suspension can either make or break a car. I DON'T WANT TO GET IT WRONG! The biggest problem I have is I don't have any actual experience of either springs & shocks or coilovers, so I'm relying entirely on the advice and experience of others.
Please help and sorry about the long post.
Thanks,
Ben.
