Author Topic: VAG part numbers for batteries, bulbs, fluids & other stuff  (Read 51930 times)
Offline Teutonic_Tamer
Official VAG part numbers, available from all VAG marque and TPS outlets.  Prices (+VAT) are from ETKA (unless stated otherwise), so in reality, dealer prices will usually be about 15-20% lower.  If anyone does actually buy any, then can post the actual price you paid (including retail, and any "discount"), and I will re-edit my post.
batteries (normally top-spec german Varta items):
  • 000 915 105 AA - 36Ah; CCA 175A DIN, 300A EN/SAE; 212W x 175L x 175H - Lupo, Polo 6N, Golf2
  • 000 915 105 AB - 44Ah; CCA 220A DIN, 360A EN/SAE; 212W x 175L x 175H - various (PR: J1P)
  • 1K0 915 105 - 44Ah; CCA 220A DIN, 360A EN/SAE; 200W x 170L x 190H - Golf5 1.4TSI 140PS (PR: J1P)
  • 7N0 915 105 - 51Ah; CCA 208A DIN, ???A EN/SAE; ???W x ???L x ???H - 8P A3 (PR: J2S)
  • 8N7 915 105 A - 52Ah; CCA ???A DIN, 480A EN/SAE; 247W x 175L x 190H - TT1 (PR: ???)
  • 000 915 105 AC - 60Ah; CCA 280A DIN, ???A EN/SAE; ???W x ???L x ???H - various (PR: J1L)
  • 000 915 105 AD - 61Ah; CCA 330A DIN, 540A EN/SAE; 246W x 175L x 190H - various, inc Golf5 GT 2.0TDI DPF 170PS (PR: J0N)
  • 000 915 105 CC - 68Ah; CCA ???A DIN, 680A EN/SAE; 278W x 175L x 190H - various (PR: ???)
  • 000 915 105 AE - 70Ah; CCA 340A DIN, 570A EN/SAE; 278W x 175L x 190H - various, inc Golf4, Golf5 GTI Ed30 (230PS), C6 A6, B8 A4 (PR: J0L)
  • 000 915 105 AF - 72Ah; CCA 380A DIN, 640A EN/SAE; 278W x 175L x 190H - various, inc Golf5 GTI (200PS) (PR: J1D)
  • 000 915 105 CD - 75Ah; CCA 420A DIN, 600A EN/SAE; 278W x 175L x 190H - various, inc Golf5 R32, B8 A4 (PR: J1N)
  • 000 915 105 AG - 80Ah; CCA 380A DIN, 640A EN/SAE; 315W x 175L x 190H - various, inc B6/B7 S4, B8 A4, C6 A6, Q7 (PR: J0R)
  • 000 915 105 AJ - 82Ah; CCA 420A DIN, 720A EN/SAE; 315W x 175L x 190H - various, inc B5 Pissrat (PR: ???)
  • 000 915 105 CE - 92Ah; CCA 520A DIN, 850A EN/SAE; 353W x 175L x 190H - various, inc B8 A4, Q7, Phaeton (PR: J0B)
  • 000 915 105 AH - 95Ah; CCA 450A DIN, 760A EN/SAE; 353W x 175L x 190H - various, inc B6/B7/B8 A4, R8, Q7 (PR: J1U)
  • 000 915 105 AK - 110Ah; CCA 520A DIN, 850A EN/SAE; 393W x 175L x 190H - various, inc B7 RS4, B8 A4, C6 A6-RS6, D2/D3 A8/S8, R8, Q7 (PR: J0Z)
FLUIDS:
VW G12++ coolant additive (antifreeze concentrate)
  • G  012 A8G M1 - 1½ lit
VW Brake Fluid, DOT4, low viscosity (for ABS/ESP), VW 501.14 (VW 501.14 is compulsory for my2008 and newer!)
  • B  000 750 M1 - ¼ lit
  • B  000 750 M3 - 1 lit
  • B  000 750 M6 - 10 lit
ENGINE OILS:
For interesting info discussing LongLife vs Time & Distance servicing regimes and oils, look here: www.golfgtiforum.co.uk/index.php?topic=65779, and here: www.golfgtiforum.co.uk/index.php?topic=98261
Engine Oils - Volkswagen Original Teile®:
VW engine oil, Special E multigrade, 15w40, VW 501.01/505.00 (mineral)
  • G  052 107 M2 - 1 lit
  • G  052 107 M4 - 5 lit
  • G  052 107 M6 - 60 lit
VW engine oil, Special Plus high lubricity PD Diesel, 5w40, VW 502.00/505.00/505.01 (semi-synthetic)
  • G  052 167 M2 - 1 lit
  • G  052 167 M4 - 5 lit
  • G  052 167 M6 - 60 lit
VW engine oil, LongLife2, 0w30 (HTHS 3.0), VW 503.00/506.00/506.01 (fully synthetic)
  • G  052 183 M2 - 1 lit
  • G  052 183 M4 - 5 lit
  • G  052 183 M6 - 60 lit
VW engine oil, LongLife3, 5w30, VW 504.00/507.00 (fully synthetic)
  • GAU 052 195 M2 - 1 lit - 'Audi' pack
  • GVW 052 195 M2 - 1 lit - 'Volkswagen' pack
  • G  052 195 M4 - 5 lit
  • G  052 195 M6 - 60 lit
Engine Oils - Quantum (these are made by Castrol for Volkswagen Group UK):
Quantum SL Multigrade Advanced, 15w40, VW 501.01/505.00, ACEA: A3/B3, API SL/CF; (mineral)
  • ZGB 115 QLB 004 00 - 1 lit
  • ZGB 115 QLB 004 01 - 5 lit
  • ZGB 115 QLB 040 2L  - 20 lit
  • ZGB 115 QLB 004 03 - 208 lit
Quantum Turbo Diesel, 15w40, VW 505.00, ACEA: A2/B2/E2, API SH/CF-4; (mineral)
  • ZGB 115 QLB 004 29 - 1 lit
  • ZGB 115 QLB 004 30 - 5 lit
  • ZGB 115 QLB 043 2L  - 20 lit
  • ZGB 115 QLB 004 23 - 208 lit
Quantum Synta, 10w40, VW 500.00/505.00, ACEA: A3/B3, API SL/CF; (semi-synthetic)
  • ZGB 115 QLB 004 05 - 1 lit
  • ZGB 115 QLB 004 06 - 5 lit
  • ZGB 115 QLB 040 7L  - 20 lit
  • ZGB 115 QLB 004 08 - 208 lit
Quantum Platinum, 5w40, VW 502.00/505.00/505.01, ACEA: A3/B3/B4/C3, API SL/CF, Ford WSS M2C917A (this replaces Synta Gold and PD Diesel); (fully synthetic)
  • ZGB 115 QLB 005 10 - 1 lit
  • ZGB 115 QLB 005 11 - 5 lit
  • ZGB 115 QLB 005 12 - 20 lit
  • ZGB 115 QLB 005 13 - 208 lit
Quantum Synta ED, 0w30, VW 503.01; (fully synthetic)
  • ZGB 115 QLB 004 92 - 5 lit
  • ZGB 115 QLB 049 3L - 20 lit
Quantum LongLife2, 0w30 (HTHS 3.0), VW 503.00/506.00/506.01; (fully synthetic)
  • ZGB 115 QLB 004 81 - 1 lit
  • ZGB 115 QLB 004 82 - 5 lit
  • ZGB 115 QLB 048 3L - 20 lit
Quantum LongLife3, 5w30, VW 504.00/507.00; (fully synthetic)
  • ZGB 115 QLB 005 00 - 1 lit
  • ZGB 115 QLB 005 01 - 5 lit
  • ZGB 115 QLB 005 02 - 20 lit
  • ZGB 115 QLB 005 03 - 208 lit
BULBS:
These are all top quality OEM specification bulbs, only sourced from Philips, Osram or GE.
Notes:
For the "blue" bulbs, these are just a normal bulb with a blue outer coating on the glass, and produce an "ice white" light output, similar in colour to HIDs/Xenons (and not the "chavvy blue" tinge).
"LL" after the bulb designation simply means a "LongLife" version of the standard bulb.
Bulb sets:
  • 000 998 203 - bulb set, blue, H7 & W5W (just two H7 blues and two W5W blues), £25
HID (Xenon gas dishcarge) headlamp capsules:
  • N  105 661 03 - D1S, 85V 35W, £130
  • N  104 457 01 - D2S, 85V 35W, £130
  • N  107 218 01 - D3S, 42V 35W, £128.50 (latest facelift A3 and new B8 A4)
Halogen headlamp & front foglamp bulbs:
  • N  017 761 2 - H1, 55W, £5
  • N  017 761 6 - H1, 55W, blue, £8.35
  • N  017 762 2 - H3, 55W, £5
  • N  017 763 2 - H4 (P43t cap), 60/55W, £5
  • N  017 763 6 - H4 (P43t cap), 60/55W, blue, £8.05
  • N  017 764 3 - H4 (P43t cap), 60/55W, yellow, £9.40 (for that 1970s "french" look  :embarassed:)
  • N  103 201 01 - H7, 55W, £9.70
  • N  103 201 03 - H7, 55W, blue, £11.10
  • N  103 201 02 - H7LL, 55W, longlife, £12.05
  • N  103 201 04 - H7LL, 55W, super longlife, £15.95
  • N  105 662 01 - HB3, 60W, £11.10
  • N  101 300 01 - HB4, 55W, £11.10
  • N  105 297 01 - H11LL, 55W, longlife, £16.25
mini Halogen bulbs: (use in certain indicator, sidelamp and tail lamps)
  • N  104 455 02 - H6W, 6W, £6.35 (Golf5 rear indicator, B6 A4 range front sidelamp)
  • N  104 456 02 - H21WLL, 21W, longlife, £5.95 (Golf5 front indicator - Bi-Xenon only)
SCC tungsten bulbs: (typical indicator, reverse, rear fog, and tail lamps)
  • N  017 732 2 - P21W, 21W, £1.20
  • N  017 732 8 - P21WLL, 21W, longlife, £2.10
  • N  102 564 01 - PY21W, 21W, orange, £2.70 (for indicators)
  • N  102 564 02 - PY21W, 21W, orange/blue, £9.70 (front indicators - orange light, with blue coating to stop the "fried egg" look - Osram Diadem)
  • N  102 564 04 - PY21W SV, 21W, orange/silver, £9.40 (front indicators - orange light, with silver coating to stop the "fried egg" look)
  • N  102 564 05 - PY21W, 25.5W, orange, longlife, £4.00 (for indicators)
  • N  102 510 02 - P21/4WLL, 21/4W, longlife, £2.70 (dual filament)
  • N  017 738 6 - P21/5WLL, 21/5W, longlife, £2.10 (dual filament)
festoon bulbs (glass cylinders with contacts each end): (number plate lamps, interior lamps, make-up, footwell and door puddle lights)
  • N  017 725 2 - C5W, 5W, £1.50
  • N  017 725 4 - C5WLL, 5W, longlife, £2.00
  • N  017 723 4 - K10W, 10W, £0.91 (Golf5 boot lamp)
capless bulbs (bulbs without any "cap" :tongue:): (side lamps, interior lamps, make-up, footwell and door puddle lights)
  • N  017 752 2 - W3W, 3W, £0.70 (Golf5 footwells, all gloveboxes with coolbox)
  • N  017 753 2 - W5W, 5W, £0.70 (Golf5 front and rear interior map reading lamps)
  • N  017 753 5 - W5WLL, 5W, longlife, £2.00
  • N  017 753 8 - W5W, 5W, blue, retail £3.18, trade £2.86 (Golf5 front parking lamps/sidelamps)
  • N  017 753 10 - W5W, 5W, blue, £3.60 (alternative part number)
  • N  017 753 11 - WY5W, 5W, orange, £2.70 (for side repeater indicators on front wings)
  • N  910 701 01 - W6W, 6W, £3.60 (Golf5 puddle lights in door mirrors)
  • N  105 915 01 - W16W, 16W, £2.40 (latest facelift A3 rear 3dr brakelight)
miscelaneous bulbs (which don't fit into any of the above categories):
  • N  900 349 01 - T4W (MCC, Ba9s), 5W, £0.70
If I have missed any specific bulbs out, reply to the thread, and state the model of car they are for, along with the model year too (indicated by the 10th digit of your VIN).
« Last Edit: 12 September 2009, 23:27 by Teutonic_Tamer »
I feel like a homo
Offline NEWEY
Re: VAG part numbers for bulbs
« Reply #1 on: 22 October 2008, 14:43 »
thanks for your help :) been looking for a set for mine
« Reply #2 on: 22 October 2008, 14:56 »
Thanks.  Spread the word on this thread, so it don't get lost into oblivion.  :smiley:
I feel like a homo
Re: VAG part numbers for bulbs, batteries & other stuff
« Reply #3 on: 19 February 2009, 17:25 »
Now added part numbers for main batteries.  :smiley:
I feel like a homo
Re: VAG part numbers for batteries, bulbs, fluids & other stuff
« Reply #4 on: 19 February 2009, 18:14 »
Now added fluids - brake fluid and engine oils.  :wink:
I feel like a homo
« Reply #5 on: 12 September 2009, 23:28 »
Added G12++ coolant. :smiley:
I feel like a homo
