If you have upgraded from the 16" min wheel size standard brakes to the 17" min wheel size R32 ones you need to tell the cars software and set a hardware bridge. Just altering the register via VAG-COM is not enough.
Huh - WTF are you on about.
For a start, you are using "yankie" terminology for measuring brakes,
which most Brits and Europeans simply ignore (because the yankie measurements are factually incorrect and confusing to even the most basically educated European who can use a ruler or tape measure
). And all the VCDS recode is doing is altering the in-built bias compensation parameters for the differing hardware which has subsequently been fitted!
