Author Topic: Service info.  (Read 74027 times)
Offline richw911
Re: Service info.
« Reply #40 on: 27 April 2011, 19:03 »
Good info. I just changed my pollent filter. Mine was thick with muck!
Blowers working loads better now then? Ideal for summer  :cool:
Offline monty9120
Re: Service info.
« Reply #41 on: 05 May 2012, 16:03 »
what are the plastic things on the top of my engine then. they have a nut with wires on them. i was told the car doesnt have spark plugs as such
never seen it before in all my years. anyone shed some light at all. its a 99 1.8 turbo if that helps
Offline richw911
Re: Service info.
« Reply #42 on: 05 May 2012, 19:35 »
Coiklpacks? AGU engines are bolt down AUM / AUQ are just push down. Your sparkplugs are under these.  :smiley:
Offline monty9120
Re: Service info.
« Reply #43 on: 06 May 2012, 13:12 »
nice one. i did look and realised what they were straight away. these have been replaced (apparentely quite expensive) but no idea about spark plugs
is the code bkr6e for a 1.8 turbo?
Offline richw911
Re: Service info.
« Reply #44 on: 06 May 2012, 21:54 »
I use the NGK 201 pack on my AGU 1.8T  :smiley:
Offline monty9120
Re: Service info.
« Reply #45 on: 09 May 2012, 16:38 »
thanks all. what about the bosch super 4 plugs?
my coil packs have a nut on. is it normal for the connectors to be greased. im getting a bit of hesitation when its cold so not sure if they should be greased when i do the plugs?
Offline Harooshum
Re: Service info.
« Reply #46 on: 05 August 2012, 09:53 »
I don't want to post on a sticky but...  on the 1st page the best sparks are referred to as NGK201 from Hal or the same from ECP part 408440060 (http://www.eurocarparts.com/search/408440060/p/home)
When I use the car selector it says these sparks won't fit my Golf (only '97 '98 '99) and the correct ones would be ECP part 408440040 which are twice the price!  I have the AUM GTI-T (year 2000).  So either ECP have their knickers in a twist and Hal NGK201's are right, or the other way round.  I don't fancy spending £40 on sparks can someone advise as I can't be the only one to see this?  Thanks.
« Last Edit: 05 August 2012, 10:30 by Harooshum »
Offline richw911
Re: Service info.
« Reply #47 on: 07 August 2012, 14:57 »
Ah yes they must be for AGU engines - will update the post  :smiley:
Offline TrebleTA
Re: Service info.
« Reply #48 on: 16 June 2015, 11:04 »
Hi i just did a service on my 2004 1.8t with help from this forum and with the spark plugs standard ones are NGK PFR6Q(6458). yet you can use a upgrade plug IFR6Q-G(5648) leaving the preset gap at 0.7mm on the upgrade plug.
