Golf mk4
Golf mk4 how to guides + info
Wazzzer
Useful "How to" links.
Topic: Useful "How to" links. (Read 47714 times)
richw911
10k hero
The Linkmeister and an OEM Freak.
29 July 2008, 22:53 »
PDF guide to clock coding :
http://www.gwdale.co.uk/other/immo2_to_immo3_install.pdf
Info on 1.8t engines and 1.8t engine tuning
http://euroturbo.net/abouteuroturbo/
Test your DV
http://www.vaglinks.com/Docs/Misc/VAGLinks.com_DIY_Testing_a_Bosch_Diverter_Valve.pdf
Front Wiper linkage replace
http://uk-mkivs.net/forums/p/432747/2960884.aspx
1.8T clutch replace
http://myfastgti.com/volkswagen/threads/12367-2004-Mk4-1.8T-Jetta-GLI-GTI-Clutch-Replacement
Door Module
http://www.taligentx.com/passat/maintenance/doorlockmechanism/
Convenience module
http://www.scribd.com/doc/56214783/2/Control-units
Broken rear seat latch repair:
http://hubpages.com/hub/How-to-fix-a-Broken-Rear-Seat-Release-Latch-VW-MKIV-DIY
Crank Sensor
http://forums.vwvortex.com/showthread.php?3864951-DIY-cam-positioning-sensor-%28hall-sensor%29
Catch can install and PCV removal:
http://uk-mkivs.net/forums/t/269734.aspx
Boost Leak tester 1.8T:
http://www.audizine.com/forum/showthread.php/190404-DIY-ALL-1.8T-Boost-Leak-Tester
http://www.dubbersinc.com/forum/diy/2286-diy-boost-leak-tester.html
Key / Immobilizer:
http://www.myturbodiesel.com/1000q/multi/immobilizer.htm
Retro fit cruse control:
http://www.carbasics.co.uk/vw_golf_mk4_cruise_control.htm
Ariel removal:
http://dl.dropbox.com/u/961976/Aerial_Guide_MK4_Golf.pdf
Option code decoder :
http://igorweb.org/equidec/Default.aspx
Fault codes list:
http://www.airbagnews.com/PDF/Fehlercodes%20VAG%20english.pdf
Anniversary Side skirt fitting guide:
http://uk-mkivs.net/forums/p/29321/252378.aspx#252378
Boot handle remove:
http://www.r32oc.com/performance-technical/23820-help-required-mk4-tailgate-handle-removal.html
1.8T spark plug how to:
http://www.diynexus.com/vw/mk4_18t_spark_plug_change/mk4_18t_spark_plug_change.html
2WD bushes upgrade
http://uk-mkivs.net/forums/t/167165.aspx
Rear Axel bush how to:
http://uk-mkvs.net/forums/p/189654/1235357.aspx#1235357
Axel bush alignment pic
http://www.golfgtiforum.co.uk/index.php?topic=115991.30
Tie rod remove:
http://faculty.ccp.edu/faculty/dreed/campingart/jettatech/tierods/tierods.htm
Recaro seat clunk fix:
http://uk-mkivs.net/forums/p/126318/2330456.aspx
Tailgate micro-switch fix (boot light not working):
http://uk-mkivs.net/forums/t/319766.aspx
Rear wiper motor fix:
http://docs.google.com/viewer?a=v&q=cache:UpcMOF_q0DYJ:pics.tdiclub.com/data/3419/How_to_Repair_the_Rotating_Rear_Washer_Nozzle.pdf+1J6+955+711+B&hl=en&gl=uk&sig=AHIEtbSPzsTxCVx_r7VRKo_Szj8KZOqbsA
VW 1.6/1.4 chocolate gearbox faults:
http://www.btinternet.com/~a_hutton/VW_Gearbox_Failure.htm
Heated seat fix:
http://uk-mkivs.net/forums/t/130369.aspx
1.8T gearbox codes :
http://www.turbo-conversion.com/16v-turbo-conversion/16v-turbo-conversion/54
Gearbox linkage alignment :
http://www.youtube.com/watch?v=tp9ggefOjAE
AGU ignition module test:
http://forums.audiworld.com/showthread.php?p=1535031
Top mount replace:
http://forums.tdiclub.com/showthread.php?p=703226
1.8T all in one trouble shoot:
http://www.elitedubs.com/index.php?topic=988
Window regulator plastic clips replace:
http://vwgolfr32.co.uk/windowregulator/
Cambelt change 1.8T:
http://forums.vwvortex.com/zerothread?id=2840728
Water leak fix:
http://uk-mkivs.net/forums/p/51109/720456.aspx#720456
Code option decoder :
N75 valve info
http://www.peterbeers.net/vw_roadtrip/GTI/GTI_Mods/N75J/N75J.htm
Various mods
http://www.pocketrocket.ca/vwtech.htm
http://www.izvw.com
Bumper and headlight removal:
http://web.archive.org/web/20060104081720/http://home.nycap.rr.com/brandonc/headlight/
Dog Bone mount:
http://forums.vwvortex.com/zerothread?id=1588015
Coilover install:
http://noahlh.com/car/coilover_howto/
Delock guide:
http://www.r32oc.com/tutorials-guides/4301-my-mk4-delock-guide.html
Aluminum trim install:
http://00626e1.netsolhost.com/formoshun/interior2.htm
Satin black interior part numbers:
1J0867171A A94 X2 left side door grab handle £3.15 each
1J0867172A A94 X1 right side door grab handle £3.15 each
3B2867172E A94 X1 drivers side door grab and handle £10.19
3B0867175 A94 X1 little peice that goes on the drivers side! £2.50
Total £22.14
All Trim part numbers:
http://forums.vwvortex.com/zerothread?id=1313745&postid=12834925
Trim in different color options:
http://www.pgperformance.com/old/dashkits.htm
Gear knob fitting:
http://00626e1.netsolhost.com/formoshun/fitting_knob.htm
(1.4 and 1.6 have different size bores on the gear knobs.)
Gear knob removal
http://www.golfgtiforum.co.uk/index.php?topic=97087.0
Starter motor noise on start up fix:
http://www.montreal-vdubbing.com/forum/viewtopic.php?t=43
Vag com download
http://www.ross-tech.net/vag-com/download/1405/Release4091us.exe
Maf clean :
http://www.oneighturbo.com/2007/09/14/how-to-mass-air-flow-cleaning-for-the-mkiv-volkswagen/
Replace brake light switch:
http://forums.vwvortex.com/zerothread?id=1158315
http://www.geocities.com/jason_ettorre/VWBLS/BLS.htm
Bora vent / W8 light upgrade :
http://www.carbasics.co.uk/vw_golf_mk4_bora_vents.htm
W8 READING LAMP GREY W/ SUNROOF - 3B7 947 106 A 2EN
W8 READING LAMP BEIGE W/ SUNROOF - 3B7 947 106 A Y20
W8 READING LAMP GREY W/O SUNROOF - 3B7 947 105 F 2EN
W8 READING LAMP BEIGE W/O SUNROOF - 3B7 947 105 F Y20
Bora and W8 looms :
http://uk-mkivs.net/forums/t/120319.aspx
http://bambergvr6.50megs.com/passat_w8_console_DIY.htm
Change keyfob battery:
http://www.riskin.org/vwkey/
OEM Xenon headlight - Rheostat Leveling Wiring Guide
http://www.billswebspace.com/HIDleveling.pdf
http://uk-mkivs.net/forums/t/260139.aspx
Boost gauge install:
http://forums.generationdub.com/showthread.php?t=15536&page=1
http://www.42draftdesigns.com/installation/WEB_Edition1Volume4.pdf
http://pics.tdiclub.com/pdf/gauge_install_2001_VW_Golf_TDI.pdf
http://homepage.ntlworld.com/john.combes2/Vdo.htm
Oil gauge install:
http://www.42draftdesigns.com/tech.html
Speedo Clock face change :
http://www.youtube.com/watch?v=Au4kT4WEP9c&feature=related
Clock disassemble:
http://www.youtube.com/watch?v=dOEPmbBzFSU
ARB installation
http://www.autotech.com/instructions/i4251525.pdf
Fan control module replace:
http://www.nime.co.uk/content.php?fancontrollerinstall
Online Spares catalog like ETKA
http://www.vagcat.com/
Clutch pedal plastic clip fault:
http://uk-mkivs.net/forums/p/43912/346776.aspx#346776
Useful part numbers:
http://forums.vwvortex.com/zerothread?id=402331
Joey Mod :
http://www.bora.wudy.co.uk/how_annilights.shtml
1.8T TIP install:
http://www.ottawa-vdubbing.com/forums/phpBB3/viewtopic.php?f=22&t=8651
1.8T 5 piece boost pipe fit:
http://uk-mkivs.net/forums/p/119678/810133.aspx#810133
Forge 007P fit guide :
http://www.forgemotorsport.co.uk/valve.pdf
4 motion rear valance install:
http://bambergvr6.50megs.com/golfivrear4mo.htm
Rear wiper relay fault:
http://uk-mkivs.net/forums/p/164706/1080972.aspx#1080972
Repairing the Secondary Air Pump (Noise on start up)
http://uk-mkivs.net/forums/t/141240.aspx
Heated seat element fix:
http://uk-mkivs.net/forums/t/117290.aspx
VW grounds list
http://mit.edu/dennis/www/vw/grounds.html
OBD DTC Fault Codes:
http://www.obd-codes.com/
Vag com measuring blocks How to:
http://www.audizine.com/forum/showthread.php?t=115366
Bleeding brakes MKIV :
http://www.ottawa-vdubbing.com/forums/phpBB3/viewtopic.php?f=22&t=24701
Mirror cap removal :
http://forums.vwvortex.com/zerothread?&id=4099628
Rear interior light removal :
http://uk-mkivs.net/forums/t/184536.aspx
Handbrake adjust:
http://www.golfgtiforum.co.uk/index.php?topic=110028.0
Audi TT short shifter install :
http://www.ottawa-vdubbing.com/forums/phpBB3/viewtopic.php?f=22&t=13399
Last Edit: 31 July 2012, 23:03 by richw911
mattkh
Re: Useful "How to" links.
13 December 2012, 07:47 »
A link to changing the air filter :
http://www.youtube.com/watch?v=GDH_hOAmkho
Golf mk4
Wazzzer
