Author Topic: Two Bucket Method explained  (Read 22111 times)
Offline ...joe
« on: 26 July 2007, 16:18 »
this is a brief run down on the two bucket method.
it is basicly used to reduce the damage caused to paint when washing. back in the day a good old sponge was good enough but to keep your car in the best condition this will help loads and cut down on work in the future.
first things first, throw your sponges away and buy a decent lambswool mit from a multitude of places. the lambswool mit draws dirt particles into the fibres so they aren't being pushed around the surface of your paint. with a sponge the dirt has no-where to go so acts like an abrasive as you wash away. also buy two buckets.  :wink:
fill one bucket with a decent shampoo NEVER USE WASHING UP LIQUID and warm water.
fill second bucket with clean water. it helps to have different coloured buckets to help you remember which is which.
hose off the car to soften/remove loose dirt
when you wash put the lambswool mit in the shampoo bucket, wash a panel, starting with the roof. then after each panel, put the mit in the clean water bucket and clean it off.
then back in the shampoo bucket, next panel, always working panels from top to bottom.
i say have different coloured buckets as by the time you're halfway through the car both buckets will look soapy!
hose off and pat dry with a waffle weave towel and then do your polishing/waxing.
it takes more effort and seems like alot of hard work but when you see the residue left in the clean water bucket at the end, you'll see all the filth that you'd otherwise be sloshing all over your car.
« Last Edit: 20 January 2010, 13:51 by jv »
mail@trimdeluxe.co.uk
www.facebook.com/Trimdeluxe
Offline dabill
Re: Two Bucket Method explained
« Reply #1 on: 26 July 2007, 19:50 »
excellent guide! should be in the maintenence and info section!
noble tuned - and still not fast enough!
Offline MowatGTI
« Reply #2 on: 29 July 2007, 14:20 »
Brilliant.  Cheers.
Offline dan gti turbo
« Reply #3 on: 03 August 2007, 15:18 »
top man
Offline John007
« Reply #4 on: 03 August 2007, 15:26 »
Seems a good idea, have to get myself another bucket. :smiley:
Offline dubsport
  • TDI POWAR!
« Reply #5 on: 16 September 2007, 22:13 »
ohhh so thats that the two bucket method is!
cheers joe :)
Offline Wayne Orkie
« Reply #6 on: 17 September 2008, 18:17 »
Sweet, will be doing that this weekend!  :drool:
Offline DANNYGCL
  • but plug thumb and jizz cookie)
« Reply #7 on: 09 February 2009, 08:31 »
Did that on my mothers car and it really does work, the amount of dirt that would usually be eating n putting swirls into the paint made the clear bucket look like a bucket of mud. TOP CLEANING METHOD
usually I am listening to my own pistons trying to make a bid for freedom through the sump
Offline bmouthboyo
« Reply #8 on: 02 March 2009, 15:50 »
can you dip back into soapy bucket mid panel? or only after in clear one?
Offline Guy
« Reply #9 on: 02 March 2009, 16:04 »
don't contaminate a soapy bucket... always rinse your mitt in a bucket of clean water before you put it into a bucket of suds
