Author Topic: How To Repair Your Mk1 Golf Odometer 18/01/2011  (Read 20690 times)
Offline Madone_si
  • Seattle WA, USA and Middlesex, UK
How to repair your mk1 odometer
There are several threads that describe various ways to fix it:
www.4crawler.com
- This was the first link I found on the MK1 FAQ. The entire site rocks, but the odometer writeup was for a much older odometer than I have but gives you what you need to do on most.
http://www.garageprosoftware.com/scirocco/tech_odometer.htm
- This was one of the best links with some great photos from dash removal to gear fixing. But since my red gear was okay, this didn't help me with my metal gear.
http://www.vintagewatercooleds.com
- Had a very detailed writeup on the disassembly of the speedometer. It had a great suggestion about using tape to hold the number wheels in place.
http://www.drivewerks.com/tech/mult_gauge_repair.htm
- This link about Porsche speedometers was interesting because the assembly is kind of similar. It also had the great suggestion about using tape to hold the number wheels in place.
http://www.4130-products.com/step/odometer/index.htm
. This is a great site that also mentions the metal gear spinning problem. Although it didn't provide any pictures about the modifications suggested.
http://mysite.verizon.net/janvdb/vw/Body/speedo_fix.txt
- Then I ran across this curious link. It mentioned "stamping the hub of the metal gear to shrink the inner diameter. This effectively makes the gear an interference fit on the shaft. This was exactly what I wanted.
« Last Edit: 18 January 2011, 22:49 by SoundillusioN »
Old Skool Mk1 Golf Gli (82), Mk1 US Cab 85 and 83
SOLD - BLACK SOY 92
Offline mk1GiT
Re: How to repair your mk1 golf odometer
« Reply #1 on: 02 August 2007, 16:25 »
kewl, thanks for the links, I need to look at fixing mine also :)
1600 GTi daily driver
Offline BobbyT
« Reply #2 on: 02 August 2007, 19:10 »
mine has stopped working but i think its the cable!!  :undecided:
Offline mk1GiT
« Reply #3 on: 03 August 2007, 07:56 »
mine does everything but no mileage
Offline Madone_si
« Reply #4 on: 08 August 2007, 16:51 »
This is a common issue with  the red gear is usually the gear at fault for a stopped odometer. realign and use some white lithium grease to lubricate
see this link for more details... http://www.vintagewatercooleds.com/tech/Techtips/ATStechnotes/odometer/odometer.htm
SOLD - BLACK SOY 92
