hello there moonsta nice to finnally meet another caddy owner on the site.
i to have looked into lowering my caddy and i was all ready to go but the project got put on hold and has been for two years. but this is all going to change shortly as i have some spare pound notes and intend to finish the project that was started.
Back the lowering the caddy, like the others have already said you basically put the axle above the springs insteed of below, this initialy lowers the back by aprx 110mm in one go some welding is also required . you can go lower by adding lowering blocks that sit between the springs and the axle this realy slams the back which in turn makes lowering the front harder because of problems with the drive shafts and bottoming out. i was advised by other caddy owners in europe not t go lower than 60mm on the front if you intend to use the car as a daily as it causes problems. another thing to bare in mind is the coilovers they come in sets of four and not many poeple will split them
Cheers Harr1s
