what you need
11mm,13mm socket. T25 Torx, Power Steering Fluid(G 002 012)
1.remove hydraulic PUMP from car.
disconnect power cable. and use T25 Torx two unbolt next to hydraulic lines. just pull lined. it came out.
2.remove a power moter from PUMP ues T25 Torx.
3.so you see this plastic piece and piece of metal(top of pic)
you can see plastic piece is crack.
so i just make piece of metal little more thick and bend each side.
insert plastic piece. glue it.
That it, your electric pump should work as normal now
You can use plastic piece VW Parts #1E0871687
