Author Topic: Fusebox FAQ  (Read 27257 times)
Re: Fusebox FAQ
« Reply #30 on: 01 February 2010, 09:45 »
yeah there are usually a few spare! off top o my head, usually a yel/white (speedo sensor) and a 2 pin plug with a blue/red and another colour (headlight range control)
if car runs alright then dont worry about it :)
Offline Golf Singh
Re: Fusebox FAQ
« Reply #31 on: 26 May 2010, 22:49 »
Trying to figure out which wires are for the 3 stages of ignition.
The Accessory, ON, and Start (crank)
Thats according to my alarm manual
The Golf only has 2 stages Accessory and STart (crank) ... am i correct ? (for a mk3)
Anyway, sould someone point out the wires and their reference codes ... cheers.
Re: Fusebox FAQ
« Reply #32 on: 27 May 2010, 09:05 »
VW have all 3, you have coil live, x-over live and cranking :)
coil live is also known as terminal 15, x-over terminal X and cranking as terminal 50.  the ign switch has these pins labled as such too handily for you ;)
The x-over feed is fed from relay 18, it kills popwer to this circuit while cranking over. This means high powere items such as lights, wipers, blower fan etc will be switched off while cranking so maximum power goes to the starter motor.
Though I suppose accessory could also refer to pin SU on the ign switch, thats what powers the radio. This pin is live whenever the key is inserted into the ignition switch :)
Re: Fusebox FAQ
« Reply #33 on: 30 July 2010, 09:30 »
CE2 Fusebox - Rear Connections
Connections and plugs on rear of fuse/relay panel:
A1Yellow8 pinHeadlight wiring harness
A2Yellow8 pinHeadlight wiring harness
BGreen6 pinHeadlight washer wiring harness
CYellow8 pinHeadlight or wiper motor wiring harness
DGreen12 pinMiscellaneous equipment, varies (A/C, A/T, heated seats, seat belt warning, etc.)
EGreen5 pinInstrument or brake light wiring harness
FWhite10 pinEngine compartment/engine management, wiring harness, right side (position 10 open)
G1White12 pinEngine compartment/engine management, right side
G2White12 pinEngine compartment/engine management, right side (position 12 open)
H1Red10 pinSteering column switch wiring harness
H2Red8 pinSteering column switch wiring harness (position 8 open)
JRed10 pinSteering column switch wiring harness
KBlack12 pinRear wiring harness
LBlack8 pinRear/Parking brake wiring harness (position 8 open)
MBlack6 pinRear/fuel tank wiring harness
NGreen6 pinAir conditioning wiring harness
PBlue10 pinRear window defroster/fog light wiring harness
QBlue6 pinFresh air blower fan wiring harness (position 10 open)
RBlue10 pinLight switch wiring harness
SWhite5 pinEngine compartment/wiper motor wiring harness, right side
TGreen2 pinIndividual circuits
U1Blue14 pinInstrument cluster wiring harness
U2Blue14 pinInstrument cluster wiring harness
VGreen4 pinSteering column switch Multi-function indicator wiring harness
WGreen6 pinMiscellaneous optional equipment, varies with vehicle type
XGreen8 pinWarning lamp wiring harness
Yn/a1 pin4 single point connectors for terminal 30 circuit (some may be bridged with red connector)
Z1n/a1 pinSingle point connector
Z2n/a1 pinSingle point connector for terminal 31 circuit
30n/a1 pinSingle point connector for terminal 30 circuit (may be bridged to 30B with red connector)
30Bn/a1 pinSingle point connector (may be bridged to 30 with red connector)
Re: Fusebox FAQ
« Reply #34 on: 30 July 2010, 09:34 »
CE1 Fusebox - Rear Connections
ABlue28 pinInstrument cluster wiring harness
BRed28 pinInstrument cluster wiring harness (position 5 open)
CYellow22 pinEngine compartment/engine management, left side (position 10 open)
DWhite29 pinEngine compartment/wiper motor wiring harness, right side (position 6. 10, 14, 18, 27, 28 open)
EBlack18 pinRear wiring harness (position 17 open)
Gn/a1 pin10 individual circuits
HBrown6 pinAir conditioning/coolant fan relay wiring harness
KNeutral   5 pinSeat belt warning system/coolant level wiring harness
LGrey4 pinHorn wiring harness
LBlack4 pinHeadlight/dimmer switch wiring harness
MBlack2 pinSteering column switch wiring harness
MBlack2 pinHeadlight/dimmer switch wiring harness
NRed1 pinSeparately fused circuits (glow plug wiring harness)
PRed7 pin7 single point connectors for terminal 30 circuit
RGreen2 pinOpen/ECU power supply relay
Offline gazman1011
  • if your not first, your last! gotta love MK3s
Re: Fusebox FAQ
« Reply #35 on: 26 May 2011, 14:10 »
what fuse box do i have in my 1987 mk2 golf?
Offline Gareth
Re: Fusebox FAQ
« Reply #36 on: 09 July 2011, 02:06 »
i would of said ce1
